Using Dynamic Hypergraphs to Reveal the Evolution of the Business Network of a 17th Century French Woman Merchant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Many digital humanity use cases require the analysis of relationships between entities (e.g. people or countries). The analysis of those relationships is particularly difficult when these relations change over time. A common representations of such relations is through graphs, which connect pairs of entities. However, in the real world relationships are often more complex and can be better described using hypergraphs (where edges can connect more than two entities). In this paper, we present a digital humanity case study of the analysis of people mentioned in 16th and 17th Century legal documents, modeled as a dynamic hypergraph. We use a new representation called Parallel Aggregated Ordered Hypergraph. Our prototype implementation of Parallel Aggregated Ordered Hypergraph, and the benefits of the PAOH representation are discussed.
paovis.pdf (3.97 Mo) Télécharger le fichier
hal-01855675 , version 1 (08-08-2018)
  • HAL Id : hal-01855675 , version 1
Paola Valdivia, Paolo Buono, Catherine Plaisant, Nicole Dufournaud, Jean-Daniel Fekete. Using Dynamic Hypergraphs to Reveal the Evolution of the Business Network of a 17th Century French Woman Merchant. VIS 2018 - 3rd Workshop on Visualization for the Digital Humanities, Oct 2018, Berlin, Germany. ⟨hal-01855675⟩
686 Consultations
598 Téléchargements
