On the Solvability of Viewing Graphs - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2) , (3) , (1, 2)
1
2
3
A set of fundamental matrices relating pairs of cameras in some configuration can be represented as edges of a " viewing graph ". Whether or not these fundamental matrices are generically sufficient to recover the global camera configuration depends on the structure of this graph. We study characterizations of " solvable " viewing graphs, and present several new results that can be applied to determine which pairs of views may be used to recover all camera parameters. We also discuss strategies for verifying the solvability of a graph computationally.
main.pdf (369.45 Ko) Télécharger le fichier
Dates and versions
hal-01856159 , version 1 (09-08-2018)
Identifiers
  • HAL Id : hal-01856159 , version 1
Cite
Matthew Trager, Brian Osserman, Jean Ponce. On the Solvability of Viewing Graphs. European Conference on Computer Vision 2018 (ECCV 2018), Sep 2018, Munich, Germany. ⟨hal-01856159⟩
103 View
155 Download
Share
