State Representation Learning for Control: An Overview - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neural Networks Année : 2018
Representation learning algorithms are designed to learn abstract features that characterize data. State representation learning (SRL) focuses on a particular kind of representation learning where learned features are in low dimension, evolve through time, and are influenced by actions of an agent. The representation is learned to capture the variation in the environment generated by the agent's actions; this kind of representation is particularly suitable for robotics and control scenarios. In particular, the low dimension characteristic of the representation helps to overcome the curse of dimensionality, provides easier interpretation and utilization by humans and can help improve performance and speed in policy learning algorithms such as reinforcement learning. This survey aims at covering the state-of-the-art on state representation learning in the most recent years. It reviews different SRL methods that involve interaction with the environment , their implementations and their applications in robotics control tasks (simulated or real). In particular, it highlights how generic learning objectives are differently exploited in the reviewed algorithms. Finally, it discusses evaluation methods to assess the representation learned and summarizes current and future lines of research.
1802.04181.pdf (389.37 Ko) Télécharger le fichier
hal-01858558 , version 1 (21-08-2018)
Timothée Lesort, Natalia Díaz-Rodríguez, Jean-François Goudou, David Filliat. State Representation Learning for Control: An Overview. Neural Networks, 2018, 108, pp.379-392. ⟨10.1016/j.neunet.2018.07.006⟩. ⟨hal-01858558⟩
260 Consultations
847 Téléchargements
