Activity recognition from stride detection: a machine learning approach based on geometric patterns and trajectory reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Bertrand Beaufils
  • Fonction : Auteur
  • PersonId : 1024978
Frédéric Chazal
Marc Grelet
  • Fonction : Auteur
In this paper, an algorithm for activity recognition is proposed using inertial sensors worn on the ankle. This innovative approach based on geometric patterns uses a stride detector that can detect both normal walking strides and atypical strides such as small steps, side steps and backward walking that existing methods struggle to detect. It is also robust in critical situations, when for example the wearer is sitting and moving the ankle, while most algorithms in the literature would wrongly detect strides. A technique inspired by Zero Velocity Update is used on the stride detection to compute the trajectory of the device. It allows to compute relevant features for the activity recognition learning task. Compared to most algorithms in the literature, this method does not use fixed-size sliding window that could be too short to provide enough information or too long and leads to overlapping issue when the window covers two different activities.
IPIN_2018.pdf (2.79 Mo) Télécharger le fichier
hal-01864467 , version 1 (30-08-2018)
  • HAL Id : hal-01864467 , version 1
Bertrand Beaufils, Frédéric Chazal, Marc Grelet, Bertrand Michel. Activity recognition from stride detection: a machine learning approach based on geometric patterns and trajectory reconstruction. IPIN 2018 - 9th International Conference on Indoor Positioning and Indoor Navigation, Sep 2018, Nantes, France. ⟨hal-01864467⟩
398 Consultations
164 Téléchargements
