Multivariate Time-Series Analysis Via Manifold Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper presents a data-driven approach for analyzing multivariate time series. It relies on the hypothesis that high-dimensional data often lie on a low-dimensional manifold whose geometry may be revealed using manifold learning techniques. We define a notion of distance between multi-variate time series and use it to determine a low-dimensional embedding capable of describing the statistics of the signals at hand using just a few parameters. We illustrate our method on two simulated examples and two real datasets containing electroencephalographic recordings (EEG).
plcr-paper_IEEE-SSP-2018.pdf (570.73 Ko) Télécharger le fichier
hal-01868167 , version 1 (05-09-2018)
Pedro Luiz Coelho Rodrigues, Marco Congedo, Christian Jutten. Multivariate Time-Series Analysis Via Manifold Learning. SSP 2018 - 2018 IEEE Workshop on Statistical Signal Processing, Jun 2018, Fribourg-en-Brisgau, Germany. ⟨10.1109/SSP.2018.8450771⟩. ⟨hal-01868167⟩
327 Consultations
1417 Téléchargements
