On the Cost of Measuring Traffic in a Virtualized Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The current trend in application development and deployment is to package applications and services within containers or virtual machines. This results in a blend of virtual and physical resources with complex network interconnection schemas mixing virtual and physical switches along with specific protocols to build virtual networks spanning over several servers. While the complexity of this setup is hidden by private/public cloud management solutions, e.g. OpenStack, this new environment constitutes a challenge when it comes to monitor and debug performance related issues. In this paper, we introduce the problem of measuring traffic in a virtualized environment and focus on one typical scenario, namely virtual machines interconnected with a virtual switch. For this scenario, we assess the cost of continuously measuring the network traffic activity of the machines. Specifically, we seek to estimate the competition that exists to access the physical resources (e.g., CPU) of the physical server between the measurement task and the legacy application activity.
CloudNet2018.pdf (431.79 Ko) Télécharger le fichier
hal-01870293 , version 1 (07-09-2018)
Karyna Gogunska, Chadi Barakat, Guillaume Urvoy-Keller, Dino Lopez-Pacheco. On the Cost of Measuring Traffic in a Virtualized Environment. IEEE International Conference on Cloud Networking, Oct 2018, Tokyo, Japan. ⟨10.1109/CloudNet.2018.8549537⟩. ⟨hal-01870293⟩
226 Consultations
352 Téléchargements
