Extracting representations of cognition across neuroimaging studies improves brain decoding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2021
Cognitive brain imaging is accumulating datasets about the neural substrate of many different mental processes. Yet, most studies are based on few subjects and have low statistical power. Analyzing data across studies could bring more statistical power; yet the current brain-imaging analytic framework cannot be used at scale as it requires casting all cognitive tasks in a unified theoretical framework. We introduce a new methodology to analyze brain responses across tasks without a joint model of the psychological processes. The method boosts statistical power in small studies with specific cognitive focus by analyzing them jointly with large studies that probe less focal mental processes. Our approach improves decoding performance for 80% of 35 widely-different functional-imaging studies. It finds commonalities across tasks in a data-driven way, via common brain representations that predict mental processes. These are brain networks tuned to psychological manipulations. They outline interpretable and plausible brain structures. The extracted networks have been made available; they can be readily reused in new neuro-imaging studies. We provide a multi-study decoding tool to adapt to new data.
article.pdf (5.07 Mo) Télécharger le fichier
hal-01874713 , version 1 (14-09-2018)
hal-01874713 , version 2 (18-10-2018)
hal-01874713 , version 3 (18-05-2021)
Arthur Mensch, Julien Mairal, Bertrand Thirion, Gaël Varoquaux. Extracting representations of cognition across neuroimaging studies improves brain decoding. PLoS Computational Biology, 2021, 17 (5), pp.e1008795:1-20. ⟨10.1371/journal.pcbi.1008795⟩. ⟨hal-01874713v3⟩
1091 Consultations
391 Téléchargements
