Data-Locality Aware Dynamic Schedulers for Independent Tasks with Replicated Inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper we concentrate on a crucial parameter for efficiency in Big Data and HPC applications: data locality. We focus on the scheduling of a set of independant tasks, each depending on an input file. We assume that each of these input files has been replicated several times and placed in local storage of different nodes of a cluster, similarly of what we can find on HDFS system for example. We consider two optimization problems, related to the two natural metrics: makespan optimization (under the constraint that only local tasks are allowed) and communication optimization (under the constraint of never letting a processor idle in order to optimize makespan). For both problems we investigate the performance of dynamic schedulers, in particular the basic greedy algorithm we can for example find in the default MapReduce scheduler. First we theoretically study its performance, with probabilistic models, and provide a lower bound for communication metric and asymptotic behaviour for both metrics. Second we propose simulations based on traces from a Hadoop cluster to compare the different dynamic schedulers and assess the expected behaviour obtained with the theoretical study.
cebda.pdf (397.24 Ko) Télécharger le fichier
hal-01878977 , version 1 (21-09-2018)
Olivier Beaumont, Thomas Lambert, Loris Marchal, Bastien Thomas. Data-Locality Aware Dynamic Schedulers for Independent Tasks with Replicated Inputs. IPDPSW 2018 IEEE International Parallel and Distributed Processing Symposium Workshops, May 2018, Vancouver, Canada. pp.1-8, ⟨10.1109/IPDPSW.2018.00187⟩. ⟨hal-01878977⟩
139 Consultations
166 Téléchargements
