Study of a Combinatorial Game in Graphs Through Linear Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithmica Année : 2020
In the Spy game played on a graph G, a single spy travels the vertices of G at speed s, while multiple slow guards strive to have, at all times, one of them within distance d of that spy. In order to determine the smallest number of guards necessary for this task, we analyze the game through a Linear Programming formulation and the fractional strategies it yields for the guards. We then show the equivalence of fractional and integral strategies in trees. This allows us to design a polynomial-time algorithm for computing an optimal strategy in this class of graphs. Using duality in Linear Programming, we also provide non-trivial bounds on the fractional guard-number of grids and tori, which gives a lower bound for the integral guard-number in these graphs. We believe that the approach using fractional relaxation and Linear Programming is promising to obtain new results in the field of combinatorial games.
spygame_trees_grids_July18.pdf (648.64 Ko) Télécharger le fichier
hal-01881473 , version 1 (10-10-2018)
Nathann Cohen, Fionn Mc Inerney, Nicolas Nisse, Stéphane Pérennes. Study of a Combinatorial Game in Graphs Through Linear Programming. Algorithmica, 2020, 82 (2), pp.212-244. ⟨10.1007/s00453-018-0503-9⟩. ⟨hal-01881473⟩
550 Consultations
208 Téléchargements
