Abstract : A standard design pattern found in many concurrent data structures , such as hash tables or ordered containers, is an alternation of parallelizable sections that incur no data conflicts and critical sections that must run sequentially and are protected with locks. A lock can be viewed as a queue that arbitrates the order in which the critical sections are executed, and a natural question is whether we can use stochastic analysis to predict the resulting throughput. As a preliminary evidence to the affirmative, we describe a simple model that can be used to predict the throughput of coarse-grained lock-based algorithms. We show that our model works well for CLH lock, and we expect it to work for other popular lock designs such as TTAS, MCS, etc.
