New interface
Conference papers
Comparative study of Line Scan and Flying Line Active IR Thermography operated with a 6-axis robot
Abstract : In this paper, two Non Destructive Testing approaches by active infrared thermography mounted on a 6-axis robot are presented and studied. Data acquisition and thermal excitation is carried out dynamically over various CFRP specimens with increasing geometry complexity, from planar, to convex and concave shapes. An automated procedure is proposed to reconstruct thermal image sequences issued from the two scanning procedure studied: Line Scan and Flying Line procedures. Defective area detection is performed by image processing and an inverse technique based on thermal quadrupole method is used to map the depth of flaws. Results obtained are discussed and perspectives are addressed.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01890846
Contributor : Laurent Mevel Connect in order to contact the contributor
Submitted on : Tuesday, October 9, 2018 - 9:58:57 AM
Last modification on : Friday, June 17, 2022 - 1:28:31 PM
Long-term archiving on: : Thursday, January 10, 2019 - 1:23:45 PM
File
QIRT_2018_YM_LG_et_al_Final_pr...
Identifiers
Collections
Citation
Yacine Mokhtari, Ludovic Gavérina, Clemente Ibarra-Castanedo, Matthieu Klein, P. Servais, et al.. Comparative study of Line Scan and Flying Line Active IR Thermography operated with a 6-axis robot. QIRT 2018 - 14th Quantitative InfraRed Thermography Conference, Jun 2018, Berlin, Germany. pp.1-10, ⟨10.21611/qirt.2018.080⟩. ⟨hal-01890846⟩
Share
Metrics
Record views
72
Files downloads
231
