Dynamics and control of a periodically forced microalgae culture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IFAC-PapersOnLine Année : 2019
Microalgae cultivation with wastewater is a promising way of reducing the energetic needs for wastewater treatment and the costs of biofuel production. However, the very turbid medium is not favorable for the development of microalgae. Indeed, light, the key element for photosynthesis, rapidly vanishes along depth due to absorption and scattering. Therefore it is crucial to understand the effects of the depth on turbid cultures. In this work, we study theoretically the long-term behavior of a continuous culture of microalgae exposed to a periodic source of light. By allowing periodic variations of the depth and the hydraulic retention time, we show that the microalgae population is forced to a periodic regime. Finally, we address numerically the problem of determining the optimal variations of the depth and the hydraulic retention time for maximizing the productivity of the culture in the periodic regime.
Automatique
dycops_final.pdf (410.27 Ko) Télécharger le fichier
hal-01891648 , version 1 (09-10-2018)
Carlos Martínez, Francis Mairet, Pierre Martinon, Olivier Bernard. Dynamics and control of a periodically forced microalgae culture. IFAC-PapersOnLine, 2019, 52, pp.922-927. ⟨10.1016/j.ifacol.2019.06.180⟩. ⟨hal-01891648⟩
254 Consultations
189 Téléchargements
