Model Development and Light Effect on a Rotating Algal Biofilm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Proceedings/Recueil Des Communications Année : 2019
The idea relying on attached culture for microalgae production has attracted manyinterest these past years due to their energy efficiency and low water usage. Microalgae cangrow and attach to the surface of an appropriate material to form a biofilm. In this paper, arotating algal biofilm (RAB) model is introduced. It is based on the Han model. How lightaffects the growth and productivity of microalgae and thus the formed biofilm will be discussedthrough model development, more importantly, it will be seen that taking into considerationlight dilution factor can increase productivity. The benefit of the system is assessed when theconveyer velocity is fast enough. Simulation show an optimal folding of the conveyer. Actualproductivities for moderate velocities are assessed and compared to these extreme cases.
Automatique
dycops_last.pdf (394.85 Ko) Télécharger le fichier
dycops.pdf (31.98 Ko) Télécharger le fichier
hal-01891661 , version 1 (09-10-2018)
hal-01891661 , version 2 (20-12-2018)
Ouassim Bara, Hubert Bonnefond, Olivier Bernard. Model Development and Light Effect on a Rotating Algal Biofilm. 2019, ⟨10.1016/j.ifacol.2019.06.091⟩. ⟨hal-01891661v2⟩
504 Consultations
481 Téléchargements
