Construction and analysis of fourth order, energy consistent, family of explicit time discretizations for dissipative linear wave equations.
Abstract : This paper deals with the construction of a family of fourth order, energy consistent, explicit time discretizations for dissipative linear wave equations. The schemes are obtained by replacing the inversion of a matrix, that comes naturally after using the technique of the Modified Equation on the second order Leap Frog scheme applied to dissipative linear wave equations, by explicit approximations of its inverse. The stability of the schemes are studied using an energy analysis and a convergence analysis is carried out. Numerical results in 1D illustrate the space/time convergence properties of the schemes and their efficiency is compared to more classical time discretizations.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
https://hal.inria.fr/hal-01894238
Contributor : Juliette Chabassier <>
Submitted on : Friday, October 12, 2018 - 12:56:34 PM
Last modification on : Friday, June 7, 2019 - 3:16:15 PM
Long-term archiving on : Sunday, January 13, 2019 - 2:11:37 PM
File
main.pdf
Identifiers
  • HAL Id : hal-01894238, version 1
Citation
Juliette Chabassier, Julien Diaz, Sébastien Imperiale. Construction and analysis of fourth order, energy consistent, family of explicit time discretizations for dissipative linear wave equations.. 2018. ⟨hal-01894238⟩
Share
Metrics
Record views
135
Files downloads
64
