Construction and convergence analysis of conservative second order local time discretisation for linear wave equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2021
In this work we present and analyse a time discretisation strategy for linear wave equations t hat aims at using locally in space the most adapted time discretisation among a family of implicit or explicit centered second order schemes. The proposed family of schemes is adapted to domain decomposition methods such as the mortar element method. They correspond in that case to local implicit schemes and to local time stepping. We show that, if some regularity properties of the solution are satisfied and if the time step verifies a stability condition, then the family of proposed time discretisations provides, in a strong norm, second order space-time convergence. Finally, we provide 1D and 2D numerical illustrations that confirm the obtained theoretical results and we compare our approach on 1D test cases to other existing local time stepping strategies for wave equations.
m2an200139.pdf (1.72 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03309010 , version 1 (29-07-2021)
Juliette Chabassier, Sébastien Imperiale. Construction and convergence analysis of conservative second order local time discretisation for linear wave equations. ESAIM: Mathematical Modelling and Numerical Analysis, 2021, 55 (4), pp.1507-1543. ⟨10.1051/m2an/2021030⟩. ⟨hal-03309010⟩
567 Consultations
402 Téléchargements
