Fingerprinting Big Data: The Case of KNN Graph Construction
Empreintes numériques et Big Data: le cas de la construction des graphes KNN
We propose fingerprinting, a new technique that consists in constructing compact, fast-to-compute and privacy-preserving binary representations of datasets. We illustrate the effectiveness of our approach on the emblematic big data problem of K-Nearest-Neighbor (KNN) graph construction and show that fingerprinting can drastically accelerate a large range of existing KNN algorithms, while efficiently obfuscating the original data, with little to no overhead. Our extensive evaluation of the resulting approach (dubbed GoldFinger) on several realistic datasets shows that our approach delivers speedups of up to 78.9% compared to the use of raw data while only incurring a negligible to moderate loss in terms of KNN quality. To convey the practical value of such a scheme, we apply it to item recommendation, and show that the loss in recommendation quality is negligible.
