Day-ahead time series forecasting: application to capacity planning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In the context of capacity planning, forecasting the evolution of informatics servers usage enables companies to better manage their computational resources. We address this problem by collecting key indicator time series and propose to forecast their evolution a day-ahead. Our method assumes that data is structured by a daily seasonality, but also that there is typical evolution of indicators within a day. Then, it uses the combination of a clustering algorithm and Markov Models to produce day-ahead forecasts. Our experiments on real datasets show that the data satisfies our assumption and that, in the case study, our method outperforms classical approaches (AR, Holt-Winters).
ts_workshop_cl.pdf (267.9 Ko) Télécharger le fichier
hal-01912002 , version 1 (05-11-2018)
Colin Leverger, Vincent Lemaire, Simon Malinowski, Thomas Guyet, Laurence Rozé. Day-ahead time series forecasting: application to capacity planning. AALTD'18 - 3nd ECML/PKDD Workshop on Advanced Analytics and Learning on Temporal Data, Sep 2018, Dublin, Ireland. ⟨hal-01912002⟩
240 Consultations
165 Téléchargements
