Using a Social-Based Collaborative Filtering with Classification Techniques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, a social-based collaborative filtering model named SBCF is proposed to make personalized recommendations of friends in a social networking context. The social information is formalized and combined with the collaborative filtering algorithm. Furthermore, in order to optimize the performance of the recommendation process, two classification techniques are used: an unsupervised technique applied initially to all users using the Incremental K-means algorithm and a supervised technique applied to newly added users using the K-Nearest Neighbors algorithm (K-NN). Based on the proposed approach, a prototype of a recommender system is developed and a set of experiments has been conducted using the Yelp database.
467079_1_En_24_Chapter.pdf (157.16 Ko) Télécharger le fichier
hal-01913883 , version 1 (06-11-2018)
Paternité
Lamia Berkani. Using a Social-Based Collaborative Filtering with Classification Techniques. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.267-278, ⟨10.1007/978-3-319-89743-1_24⟩. ⟨hal-01913883⟩
49 Consultations
29 Téléchargements
