Automatic Recognition of Plant Leaves Using Parallel Combination of Classifiers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Because they are exploited in many fields such as medicine, agriculture, chemistry and others, plants are of fundamental importance to life on earth. Before it can be used, a plant need to firstly be identified and categorized. However, a manual identification task requires time, and it is not an easy task to do. This is because some plants look visually similar to the human eye, whereas some others may be unknown to it. Therefore, there has been an increasing interest in developing a system that automatically fulfils such tasks fast and accurate. In this paper, we propose an automatic plant classification system based on a parallel combination technique of multiple classifiers. We have considered using three widely known classifiers namely Naïve Bayes (NB), K-Nearest Neighbour (KNN) and Support Vector Machine (SVM). Our system has been evaluated using the well-known Flavia dataset. It has shown a better performance than those obtained using only one classifier.
467079_1_En_51_Chapter.pdf (821.75 Ko) Télécharger le fichier
hal-01913912 , version 1 (07-11-2018)
Paternité
Lamis Hamrouni, Ramla Bensaci, Mohammed Lamine Kherfi, Belal Khaldi, Oussama Aiadi. Automatic Recognition of Plant Leaves Using Parallel Combination of Classifiers. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.597-606, ⟨10.1007/978-3-319-89743-1_51⟩. ⟨hal-01913912⟩
73 Consultations
91 Téléchargements
