Modular Design of Domain-Specific Languages using Splittings of Catamorphisms - Archive ouverte HAL Access content directly
Conference Papers Year : 2018
(1) , (2)
1
2
Language oriented programming is an approach to software composition based on domain specific languages (DSL) dedicated to specific aspects of an application domain. In order to combine such languages we embed them into a host language (namely Haskell, a strongly typed higher-order lazy functional language). A DSL is then given by an algebraic type, whose operators are the constructors of abstract syntax trees. Such a multi-sorted signature is associated to a polynomial functor. An algebra for this functor tells us how to interpret the programs. Using Beki´cBeki´c's Theorem we define a modular decomposition of algebras that leads to a class of parametric multi-sorted signatures, associated with regular functors, allowing for the modular design of DSLs.
BadouelDjeumen.pdf (215.58 Ko) Télécharger le fichier
Dates and versions
hal-01919423 , version 1 (12-11-2018)
Identifiers
Cite
Eric Badouel, Rodrigue Djeumen Djatcha. Modular Design of Domain-Specific Languages using Splittings of Catamorphisms. ICTAC 2018 - 15th International Colloquium on the Theoretical Aspects of Computing, Oct 2018, Stellenbosch, South Africa. pp.62-79, ⟨10.1007/978-3-030-02508-3_4⟩. ⟨hal-01919423⟩
86 View
258 Download
Share
