Negation in event semantics with actual and nonactual events - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The goal of this work is to provide a formal account of negation in a Davidsonian framework that (i) makes negative events available for the analysis of various constructions that are otherwise problematic (such as negative naked infinitives or adverbial modification) and (ii) exhibits reasonable logical properties. This is done by first distinguishing between actual and non-actual events and then introducing a Neg function sending any event-predicate P to the not-P event and obeying a single axiom.
Linguistique
console26-final-Bernard.pdf (268.98 Ko) Télécharger le fichier
hal-01931273 , version 1 (18-07-2019)
  • HAL Id : hal-01931273 , version 1
Timothée Bernard. Negation in event semantics with actual and nonactual events. ConSOLE 2018 - 26th Conference of the Student Organization of Linguistics in Europe, Feb 2018, London, United Kingdom. pp.350-366. ⟨hal-01931273⟩
136 Consultations
946 Téléchargements
