Service for MANET node self-configuration and communication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Setting up a MANET is a complex task, involving the configuration of a routing protocol and the network parameters of the nodes, since there is no centralized point for distribution of IP addresses. This complexity is further compounded by the absence of a name resolution system. We describe NetService, a service that frees application developers and deployers from this burden. NetService runs on the nodes and auto-configures a predefined MANET at the request of applications. It handles IP address assignment and includes a name resolution mechanism that provides a hierarchical naming scheme and is compatible with a standard resolver. The service provides an API to configure the nodes and another one for exchanging messages, abstracting applications from the details of network access.
paper 1.pdf (270.77 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01935197 , version 1 (26-11-2018)
Paternité
  • HAL Id : hal-01935197 , version 1
Eduardo Soares, Ana Aguiar, Pedro Brandão, Rui Prior. Service for MANET node self-configuration and communication. 11th IFIP Wireless and Mobile Networking Conference (WMNC 2018), Sep 2018, Prague, Czech Republic. pp.1-8. ⟨hal-01935197⟩
103 Consultations
176 Téléchargements
