Exact conversion from Bézier tetrahedra to Bézier hexahedra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Geometric Design Année : 2018
Modeling and computing of trivariate parametric volumes is an important research topic in the field of three-dimensional isogeo-metric analysis. In this paper, we propose two kinds of exact conversion approaches from Bézier tetrahedra to Bézier hexahedra with the same degree by reparametrization technique. In the first method, a Bézier tetrahedron is converted into a degenerate Bézier hexahedron, and in the second approach, a non-degenerate Bézier tetrahedron is converted into four non-degenerate Bézier hexahedra. For the proposed methods, explicit formulas are given to compute the control points of the resulting tensor-product Bézier hexahedra. Furthermore, in the second method, we prove that tetrahedral spline solids with C k-continuity can be converted into a set of tensor-product Bézier volumes with G k-continuity. The proposed methods can be used for the volumetric data exchange problems between different trivariate spline representations in CAD/CAE. Several experimental results are presented to show the effectiveness of the proposed methods.
paper.pdf (4.95 Mo) Télécharger le fichier
hal-01936167 , version 1 (27-11-2018)
Gang Xu, Yaoli Jin, Zhoufang Xiao, Qing Wu, Bernard Mourrain, et al.. Exact conversion from Bézier tetrahedra to Bézier hexahedra. Computer Aided Geometric Design, 2018, 62, pp.154 - 165. ⟨10.1016/j.cagd.2018.03.022⟩. ⟨hal-01936167⟩
56 Consultations
197 Téléchargements
