PARCOACH Extension for a Full-Interprocedural Collectives Verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The advent to exascale requires more scalable and efficient techniques to help developers to locate, analyze and correct errors in parallel applications. PARallel COntrol flow Anomaly CHecker (PARCOACH) is a framework that detects the origin of collective errors in applications using MPI and/or OpenMP. In MPI, such errors include collective operations mismatches. In OpenMP, a collective error can be a barrier not called by all tasks in a team. In this paper, we present an extension of PARCOACH which improves its collective errors detection. We show our analysis is more precise and accurate than the previous one on different benchmarks and real applications.
correctness_2018.pdf (331.25 Ko) Télécharger le fichier
hal-01937316 , version 1 (28-11-2018)
  • HAL Id : hal-01937316 , version 1
Pierre Huchant, Emmanuelle Saillard, Denis Barthou, Hugo Brunie, Patrick Carribault. PARCOACH Extension for a Full-Interprocedural Collectives Verification. Second International Workshop on Software Correctness for HPC Applications, Nov 2018, Dallas, United States. ⟨hal-01937316⟩
135 Consultations
228 Téléchargements
