HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Efficient Bias-Span-Constrained Exploration-Exploitation in Reinforcement Learning
Ronan Fruit 1 Matteo Pirotta 1 Alessandro Lazaric 2 Ronald Ortner 3
1 SEQUEL - Sequential Learning
Inria Lille - Nord Europe, CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : We introduce SCAL, an algorithm designed to perform efficient exploration-exploitation in any unknown weakly-communicating Markov decision process (MDP) for which an upper bound $c$ on the span of the optimal bias function is known. For an MDP with $S$ states, $A$ actions and $\Gamma \leq S$ possible next states, we prove a regret bound of $\widetilde{O}(c\sqrt{\Gamma SAT})$, which significantly improves over existing algorithms (e.g., UCRL and PSRL), whose regret scales linearly with the MDP diameter $D$. In fact, the optimal bias span is finite and often much smaller than $D$ (e.g., $D=\infty$ in non-communicating MDPs). A similar result was originally derived by Bartlett and Tewari (2009) for REGAL.C, for which no tractable algorithm is available. In this paper, we relax the optimization problem at the core of REGAL.C, we carefully analyze its properties, and we provide the first computationally efficient algorithm to solve it. Finally, we report numerical simulations supporting our theoretical findings and showing how SCAL significantly outperforms UCRL in MDPs with large diameter and small span.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01941206
Contributor : Matteo Pirotta Connect in order to contact the contributor
Submitted on : Friday, November 30, 2018 - 6:24:07 PM
Last modification on : Wednesday, March 23, 2022 - 3:51:19 PM
Long-term archiving on: : Friday, March 1, 2019 - 4:04:19 PM
File
fruit18a-supp.pdf
Identifiers
  • HAL Id : hal-01941206, version 1
Citation
Ronan Fruit, Matteo Pirotta, Alessandro Lazaric, Ronald Ortner. Efficient Bias-Span-Constrained Exploration-Exploitation in Reinforcement Learning. ICML 2018 - The 35th International Conference on Machine Learning, Jul 2018, Stockholm, Sweden. pp.1578-1586. ⟨hal-01941206⟩
Share
Metrics
Record views
54
Files downloads
29
