Two Notions of Differential Equivalence on Sboxes
In this work, we discuss two notions of differential equivalence on Sboxes. First, we introduce the notion of DDT-equivalence which applies to vectorial Boolean functions that share the same difference distribution table (DDT). Next, we compare this notion to what we call the $γ$-equivalence, applying to vectorial Boolean functions whose DDTs have the same support. We discuss the relation between these two equivalence notions, demonstrate that the number of DDT- or $γ$--equivalent functions is invariant under EA- and CCZ-equivalence and provide an algorithm for computing the DDT-equivalence and the $γ$-equivalence classes of a given function. We study the sizes of these classes for some families of Sboxes. Finally, we prove a result that shows that the rows of the DDT of an APN permutation are pairwise distinct.
