Journal articles
Forced convection heat transfer of Giesekus fluid with wall slip above the critical shear stress in pipes
Mehdi Moayed Mohseni 1, * Gilles Tissot 2, 3, 4 Michael Badawi 1, *
* Corresponding author
3 FLUMINANCE - Fluid Flow Analysis, Description and Control from Image Sequences
IRMAR - Institut de Recherche Mathématique de Rennes, IRSTEA - Institut national de recherche en sciences et technologies pour l'environnement et l'agriculture, Inria Rennes – Bretagne Atlantique
Abstract : Forced convective heat transfer in pipes is investigated for viscoelastic fluids obeying the Giesekus constitutive equation including effect of slip condition by an approximated analytical method. The slip equation at wall is considered as a nonlinear Navier model with non-zero slip critical shear stress. The problem under consideration is steady, laminar and fully developed. Thermal boundary conditions are assumed peripherally and axially constant heat flux at wall. The fluid heating and cooling cases are considered for analysis. Dimensionless temperature profiles and Nusselt number are obtained by solving governing equations and the effects of slip parameters, viscous dissipation and fluid elasticity are discussed. Results show that Nusselt number increases by increasing slip effect but decreases by increasing Brinkman number for the case of fluid heating. However, for the cooling case, the heat generated by viscous dissipation can overcome the effect of wall cooling at first critical Brinkman number and fluid starts to warm up. Also the Nusselt curve shows a singularity in a second critical Brinkman number.
Document type :
Journal articles
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01946843
Contributor : Gilles TISSOT Connect in order to contact the contributor
Submitted on : Monday, December 10, 2018 - 10:34:55 AM
Last modification on : Friday, July 8, 2022 - 10:08:00 AM
Long-term archiving on: : Monday, March 11, 2019 - 12:44:25 PM
Identifiers
Citation
Mehdi Moayed Mohseni, Gilles Tissot, Michael Badawi. Forced convection heat transfer of Giesekus fluid with wall slip above the critical shear stress in pipes. International Journal of Heat and Fluid Flow, Elsevier, 2018, 71, pp.442-450. ⟨10.1016/j.ijheatfluidflow.2018.05.005⟩. ⟨hal-01946843⟩
Share
Metrics
Record views
113
Files downloads
227
