New interface
Conference papers
Data-driven cortical clustering to provide a family of plausible solutions to M/EEG inverse problem
Abstract : The M/EEG inverse problem is ill-posed. Thus additional hypotheses are needed to constrain the solution space. In this work, we consider that brain activity which generates an M/EEG signal is a connected cortical region. We study the case when only one region is active at once. We show that even in this simple case several configurations can explain the data. As opposed to methods based on convex optimization which are forced to select one possible solution, we propose an approach which is able to find several ”good” candidates - regions which are different in term of their sizes and/or positions but fit the data with similar accuracy.
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01946876
Contributor : Kostiantyn Maksymenko Connect in order to contact the contributor
Submitted on : Thursday, December 6, 2018 - 2:20:22 PM
Last modification on : Saturday, June 25, 2022 - 11:33:40 PM
Long-term archiving on: : Thursday, March 7, 2019 - 3:21:09 PM
Identifiers
  • HAL Id : hal-01946876, version 1
  • ARXIV : 1812.04110
Collections
Citation
Kostiantyn Maksymenko, Maureen Clerc, Théodore Papadopoulo. Data-driven cortical clustering to provide a family of plausible solutions to M/EEG inverse problem. iTWIST, Nov 2018, Marseille, France. ⟨hal-01946876⟩
Share
Metrics
Record views
101
Files downloads
35
