Data-driven cortical clustering to provide a family of plausible solutions to M/EEG inverse problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The M/EEG inverse problem is ill-posed. Thus additional hypotheses are needed to constrain the solution space. In this work, we consider that brain activity which generates an M/EEG signal is a connected cortical region. We study the case when only one region is active at once. We show that even in this simple case several configurations can explain the data. As opposed to methods based on convex optimization which are forced to select one possible solution, we propose an approach which is able to find several ”good” candidates - regions which are different in term of their sizes and/or positions but fit the data with similar accuracy.
Maksymenko_itwist18.pdf (3.91 Mo) Télécharger le fichier
poster_Maksymenko.pdf (2.76 Mo) Télécharger le fichier
Format : Poster
hal-01946876 , version 1 (06-12-2018)
Kostiantyn Maksymenko, Maureen Clerc, Théodore Papadopoulo. Data-driven cortical clustering to provide a family of plausible solutions to M/EEG inverse problem. iTWIST, Nov 2018, Marseille, France. ⟨hal-01946876⟩
102 Consultations
39 Téléchargements
