Towards BCI-based Interfaces for Augmented Reality: Feasibility, Design and Evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2018
Brain-Computer Interfaces (BCIs) enable users to interact with computers without any dedicated movement, bringing newhands-free interaction paradigms. In this paper we study the combination of BCI and Augmented Reality (AR). We first tested thefeasibility of using BCI in AR settings based on Optical See-Through Head-Mounted Displays (OST-HMDs). Experimental results showedthat a BCI and an OST-HMD equipment (EEG headset and Hololens in our case) are well compatible and that small movements of thehead can be tolerated when using the BCI. Second, we introduced a design space for command display strategies based on BCI in AR,when exploiting a famous brain pattern called Steady-State Visually Evoked Potential (SSVEP). Our design space relies on fivedimensions concerning the visual layout of the BCI menu ; namely: orientation, frame-of-reference, anchorage, size and explicitness. Weimplemented various BCI-based display strategies and tested them within the context of mobile robot control in AR. Our findings werefinally integrated within an operational prototype based on a real mobile robot that is controlled in AR using a BCI and a HoloLensheadset. Taken together our results (4 user studies) and our methodology could pave the way to future interaction schemes in AugmentedReality exploiting 3D User Interfaces based on brain activity and BCIs.
Manuscript.pdf (14.33 Mo) Télécharger le fichier
hal-01947344 , version 1 (06-12-2018)
Paternité
Hakim Si-Mohammed, Jimmy Petit, Camille Jeunet, Ferran Argelaguet Sanz, Fabien Spindler, et al.. Towards BCI-based Interfaces for Augmented Reality: Feasibility, Design and Evaluation. IEEE Transactions on Visualization and Computer Graphics, 2018, 26 (3), pp.1608-1621. ⟨10.1109/TVCG.2018.2873737⟩. ⟨hal-01947344⟩
367 Consultations
1044 Téléchargements
