When Good Components Go Bad - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We propose a new formal criterion for evaluating secure compilation schemes for unsafe languages, expressing end-to-end security guarantees for software components that may become compromised after encountering undefined behavior---for example, by accessing an array out of bounds. Our criterion is the first to model dynamic compromise in a system of mutually distrustful components with clearly specified privileges. It articulates how each component should be protected from all the others---in particular, from components that have encountered undefined behavior and become compromised. Each component receives secure compilation guarantees---in particular, its internal invariants are protected from compromised components---up to the point when this component itself becomes compromised, after which we assume an attacker can take complete control and use this component's privileges to attack other components. More precisely, a secure compilation chain must ensure that a dynamically compromised component cannot break the safety properties of the system at the target level any more than an arbitrary attacker-controlled component (with the same interface and privileges, but without undefined behaviors) already could at the source level. To illustrate the model, we construct a secure compilation chain for a small unsafe language with buffers, procedures, and components, targeting a simple abstract machine with built-in compartmentalization. We give a careful proof (mostly machine-checked in Coq) that this compiler satisfies our secure compilation criterion. Finally, we show that the protection guarantees offered by the compartmentalized abstract machine can be achieved at the machine-code level using either software fault isolation or a tag-based reference monitor.
hal-01949202 , version 1 (09-12-2018)
Paternité
Carmine Abate, Arthur Azevedo de Amorim, Roberto Blanco, Ana Nora Evans, Guglielmo Fachini, et al.. When Good Components Go Bad: Formally Secure Compilation Despite Dynamic Compromise. 25th ACM Conference on Computer and Communications Security (CCS), Oct 2018, Toronto, Canada. pp.1351--1368, ⟨10.1145/3243734.3243745⟩. ⟨hal-01949202⟩
65 Consultations
0 Téléchargements
