Degenerate String Comparison and Applications - Archive ouverte HAL Access content directly
Conference Papers Year :
(1) , (1) , (2) , (3, 4) , (1) , (3, 4) , (1) , (3)
1
2
3
4
A generalised degenerate string (GD string) S^ is a sequence of n sets of strings of total size N, where the ith set contains strings of the same length k_i but this length can vary between different sets. We denote the sum of these lengths k_0, k_1,...,k_{n-1} by W. This type of uncertain sequence can represent, for example, a gapless multiple sequence alignment of width W in a compact form. Our first result in this paper is an O(N+M)-time algorithm for deciding whether the intersection of two GD strings of total sizes N and M, respectively, over an integer alphabet, is non-empty. This result is based on a combinatorial result of independent interest: although the intersection of two GD strings can be exponential in the total size of the two strings, it can be represented in only linear space. A similar result can be obtained by employing an automata-based approach but its cost is alphabet-dependent. We then apply our string comparison algorithm to compute palindromes in GD strings. We present an O(min{W,n^2}N)-time algorithm for computing all palindromes in S^. Furthermore, we show a similar conditional lower bound for computing maximal palindromes in S^. Finally, proof-of-concept experimental results are presented using real protein datasets.
LIPIcs-WABI-2018-21.pdf (544.68 Ko) Télécharger le fichier
Dates and versions
hal-01964706 , version 1 (23-12-2018)
Identifiers
Cite
Mai Alzamel, Lorraine a K Ayad, Giulia Bernardini, Roberto P Grossi, Costas S. Iliopoulos, et al.. Degenerate String Comparison and Applications. WABI 2018 - 18th Workshop on Algorithms in Bioinformatics, Aug 2018, Helsinki, Finland. pp.1-14, ⟨10.4230/LIPIcs.WABI.2018.21⟩. ⟨hal-01964706⟩
Collections
INRIA INRIA2
43 View
72 Download
Share
