Abstract : We study the number of inclusion-minimal cuts in an undi-rected connected graph G, also called st-cuts, for any two distinct nodes s and t: the st-cuts are in one-to-one correspondence with the partitions $S ∪ T$ of the nodes of G such that $S ∩ T = ∅, s ∈ S, t ∈ T$ , and the sub-graphs induced by S and T are connected. It is easy to find an exponential upper bound to the number of st-cuts (e.g. if G is a clique) and a constant lower bound. We prove that there is a more interesting lower bound on this number, namely, $Ω(m$), for undirected m-edge graphs that are biconnected or triconnected (2-or 3-node-connected). The wheel graphs show that this lower bound is the best possible asymptotically.
