Round-Hashing for Data Storage: Distributed Servers and External-Memory Tables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper proposes round-hashing, which is suitable for data storage on distributed servers and for implementing external-memory tables in which each lookup retrieves at most one single block of external memory, using a stash. For data storage, round-hashing is like consistent hashing as it avoids a full rehashing of the keys when new servers are added. Experiments show that the speed to serve requests is tenfold or more than the state of the art. In distributed data storage, this guarantees better throughput for serving requests and, moreover, greatly reduces decision times for which data should move to new servers as rescanning data is much faster.
LIPIcs-ESA-2018-43.pdf (598.71 Ko) Télécharger le fichier
hal-01964721 , version 1 (23-12-2018)
Roberto P Grossi, Luca P Versari. Round-Hashing for Data Storage: Distributed Servers and External-Memory Tables. ESA 2018 - 26th Annual European Symposium on Algorithms, Aug 2018, Helsinki, Finland. pp.1 - 43, ⟨10.4230/LIPIcs.ESA.2018.43⟩. ⟨hal-01964721⟩
Collections
INRIA INRIA2
19 Consultations
159 Téléchargements
