On the two-filter approximations of marginal smoothing distributions in general state space models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Probability Année : 2018
A prevalent problem in general state space models is the approximation of the smoothing distribution of a state conditional on the observations from the past, the present, and the future. The aim of this paper is to provide a rigorous analysis of such approximations of smoothed distributions provided by the two-filter algorithms. We extend the results available for the approximation of smoothing distributions to these two-filter approaches which combine a forward filter approximating the filtering distributions with a backward information filter approximating a quantity proportional to the posterior distribution of the state given future observations.
twofilters_hal.pdf (300.29 Ko) Télécharger le fichier
hal-01319747 , version 1 (27-05-2016)
Thi Ngoc Minh Nguyen, Sylvain Le Corff, Éric Moulines. On the two-filter approximations of marginal smoothing distributions in general state space models. Advances in Applied Probability, 2018, 50 (1), pp.154-177. ⟨10.1017/apr.2018.8⟩. ⟨hal-01319747⟩
475 Consultations
156 Téléchargements
