Abstract : We present a system architecture implementation to perform dynamic application allocation in shared sensor networks, where highly integrated wireless sensor systems are used to support multiple applications. The architecture is based on a central controller that collects the received data from the sensor nodes, dynamically decides which applications must be simultaneously deployed in each node and, accordingly, over-the-air reprograms the sensor nodes. Waspmote devices are used as sensor nodes that communicate with the controller using ZigBee protocol. Experimental results show the viability of the proposal.
https://hal.inria.fr/hal-01995501 Contributor : Joe TurnerConnect in order to contact the contributor Submitted on : Saturday, January 26, 2019 - 10:35:29 PM Last modification on : Tuesday, August 13, 2019 - 11:10:04 AM Long-term archiving on: : Saturday, April 27, 2019 - 1:00:48 PM
Carmen Delgado, Sergio Batista, María Canales, José Ramón Gállego, Jorge Ortín, et al.. An Implementation for Dynamic Application Allocation in Shared Sensor Networks. 11th IFIP Wireless and Mobile Networking Conference (WMNC 2018), Sep 2018, Prague, Czech Republic. pp.116-123. ⟨hal-01995501⟩
