RayCursor: a 3D Pointing Facilitation Technique based on Raycasting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marc Baloup
Géry Casiez
Raycasting is the most common target pointing technique in virtual reality environments. However, performance on small and distant targets is impacted by the accuracy of the pointing device and the user’s motor skills. Current point- ing facilitation techniques are currently only applied in the context of the virtual hand, i.e. for targets within reach. We propose enhancements to Raycasting: filtering the ray, and adding a controllable cursor on the ray to select the near- est target. We describe a series of studies for the design of the visual feedforward, filtering technique, as well as a comparative study between different 3D pointing techniques. Our results show that highlighting the nearest target is one of the most efficient visual feedforward technique. We also show that filtering the ray reduces error rate in a drastic way. Finally we show the benefits of RayCursor compared to Raycasting and another technique from the literature.
paper.pdf (1.55 Mo) Télécharger le fichier
hal-02015844 , version 1 (12-02-2019)
Marc Baloup, Thomas Pietrzak, Géry Casiez. RayCursor: a 3D Pointing Facilitation Technique based on Raycasting. Proceedings of the ACM Conference on Human Factors in Computing Systems (CHI 2019), May 2019, Glasgow, United Kingdom. ⟨10.1145/3290605.3300331⟩. ⟨hal-02015844⟩
452 Consultations
1347 Téléchargements
