Introduce the term storage instance - Archive ouverte HAL Access content directly
Reports (Technical Report) Year : 2019
There is a lack of terminology to describe the entity that is reserved and released by either an allocation (malloc/free) or by the definition of a variable or compound literal. We introduce the new term storage instance to distinguish it clearly from the term object.
n2388+appendix.pdf (776.57 Ko) Télécharger le fichier
Dates and versions
hal-02046329 , version 1 (22-02-2019)
hal-02046329 , version 2 (28-06-2019)
Identifiers
  • HAL Id : hal-02046329 , version 2
Cite
Jens Gustedt. Introduce the term storage instance. [Technical Report] N2388, ISO JTC1/SC22/WG14. 2019. ⟨hal-02046329v2⟩
56 View
54 Download
Share
