A Rule Extraction Study Based on a Convolutional Neural Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Convolutional Neural Networks (CNNs) lack an explanation capability in the form of propositional rules. In this work we define a simple CNN architecture having a unique convolutional layer, then a Max-Pool layer followed by a full connected layer. Rule extraction is performed after the Max-Pool layer with the use of the Discretized Interpretable Multi Layer Perceptron (DIMLP). The antecedents of the extracted rules represent responses of convolutional filters, which are difficult to understand. However, we show in a sentiment analysis problem that from these “meaningless” values it is possible to obtain rules that represent relevant words in the antecedents. The experiments illustrate several examples of rules that represent n-grams.
472936_1_En_22_Chapter.pdf (119.79 Ko) Télécharger le fichier
hal-02060063 , version 1 (07-03-2019)
Paternité
Guido Bologna. A Rule Extraction Study Based on a Convolutional Neural Network. 2nd International Cross-Domain Conference for Machine Learning and Knowledge Extraction (CD-MAKE), Aug 2018, Hamburg, Germany. pp.304-313, ⟨10.1007/978-3-319-99740-7_22⟩. ⟨hal-02060063⟩
100 Consultations
109 Téléchargements
