Towards Semantic Process Mining Through Knowledge-Based Trace Abstraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many information systems nowadays record data about the process instances executed at the organization in the form of traces in a log. In this paper we present a framework able to convert actions found in the traces into higher level concepts, on the basis of domain knowledge. Abstracted traces are then provided as an input to semantic process mining.The approach has been tested in the medical domain of stroke care, where we show how the abstraction mechanism allows the user to mine process models that are easier to interpret, since unnecessary details are hidden, but key behaviors are clearly visible.
479562_1_En_3_Chapter.pdf (3.25 Mo) Télécharger le fichier
hal-02060703 , version 1 (07-03-2019)
Paternité
G. Leonardi, M. Striani, S. Quaglini, A. Cavallini, S. Montani. Towards Semantic Process Mining Through Knowledge-Based Trace Abstraction. 7th International Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), Dec 2017, Neuchatel, Switzerland. pp.45-64, ⟨10.1007/978-3-030-11638-5_3⟩. ⟨hal-02060703⟩
40 Consultations
60 Téléchargements
