The SYMBIONT project: symbolic methods for biological networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Communications in Computer Algebra Année : 2018
The international interdisciplinary SYMBIONT project ranges from mathematics via computer science to systems biology, with a balanced team of researchers from those fields. At the present stage the project has a clear focus on fundamental research on mathematical methods, and prototypes in software. Results are systematically benchmarked against models from computational biology databases. We summarize the motivation and aims for the project, and report on existing results by the consortium and first activities. The project website can be found at www.symbiont-project.org.
Fichier non déposé
hal-02061018 , version 1 (07-03-2019)
François Boulier, François Fages, Ovidiu Radulescu, Satya Swarup Samal, Andreas Schuppert, et al.. The SYMBIONT project: symbolic methods for biological networks. ACM Communications in Computer Algebra, 2018, 52 (3), pp.67-70. ⟨10.1145/3313880.3313885⟩. ⟨hal-02061018⟩
57 Consultations
0 Téléchargements
