Hash functions from superspecial genus-2 curves using Richelot isogenies
Abstract : Last year Takashima proposed a version of Charles, Goren and Lauter's hash function using Richelot isogenies, starting from a genus-2 curve that allows for all subsequent arithmetic to be performed over a quadratic finite field Fp2. In a very recent paper Flynn and Ti point out that Takashima's hash function is insecure due to the existence of small isogeny cycles. We revisit the construction and show that it can be repaired by imposing a simple restriction, which moreover clarifies the security analysis. The runtime of the resulting hash function is dominated by the extraction of 3 square roots for every block of 3 bits of the message, as compared to one square root per bit in the elliptic curve case; however in our setting the extractions can be parallelized and are done in a finite field whose bit size is reduced by a factor 3. Along the way we argue that the full supersingular isogeny graph is the wrong context in which to study higher-dimensional analogues of Charles, Goren and Lauter's hash function, and advocate the use of the superspecial subgraph, which is the natural framework in which to view Takashima's Fp2-friendly starting curve.
Document type :
Preprints, Working Papers, ...
Complete list of metadatas
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-02067885
Contributor : Benjamin Smith <>
Submitted on : Tuesday, June 4, 2019 - 8:52:19 PM
Last modification on : Friday, June 7, 2019 - 1:17:08 AM
File
superspecial.pdf
Identifiers
  • HAL Id : hal-02067885, version 2
  • ARXIV : 1903.06451
Collections
Citation
Wouter Castryck, Thomas Decru, Benjamin Smith. Hash functions from superspecial genus-2 curves using Richelot isogenies. 2019. ⟨hal-02067885v2⟩
Share
Metrics
Record views
51
Files downloads
249
