Anticanonical codes from del Pezzo surfaces with Picard rank one - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions of the American Mathematical Society Année : 2020
We construct algebraic geometric codes from del Pezzo surfaces and focus on the ones having Picard rank one and the codes associated to the anticanonical class. We give explicit constructions of del Pezzo surfaces of degree 4, 5 and 6, compute the parameters of the associated anticanonical codes and study their isomorphisms arising from the automorphisms of the surface. We obtain codes with excellent parameters and some of them turn out to beat the best known codes listed on the database codetable.
AnticanonicalCodesFinal_3.pdf (445.25 Ko) Télécharger le fichier
hal-02075926 , version 1 (21-03-2019)
Régis Blache, Alain Couvreur, Emmanuel Hallouin, David Madore, Jade Nardi, et al.. Anticanonical codes from del Pezzo surfaces with Picard rank one. Transactions of the American Mathematical Society, 2020, ⟨10.1090/tran/8119⟩. ⟨hal-02075926⟩
314 Consultations
358 Téléchargements
