New interface
Reports (Technical report)
Out-of-band bit for exceptional return and errno replacement
Jens Gustedt 1
1 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : We propose a mechanism for out-of-band return of exceptional conditions that are designed, among other things, to replace errno and similar thread-local mechanisms for error return, and to allow C libraries and other programming languages to implement value based exception return on top of it. Our method is designed to be conservative: there is no need of ABI replacement for platforms, only amendment, and existing executables and compiled libraries remain valid.
Document type :
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-02089873
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Thursday, April 4, 2019 - 11:33:33 AM
Last modification on : Thursday, October 27, 2022 - 4:12:04 AM
Long-term archiving on: : Friday, July 5, 2019 - 1:21:04 PM
File
n2361.pdf
Identifiers
  • HAL Id : hal-02089873, version 1
Citation
Jens Gustedt. Out-of-band bit for exceptional return and errno replacement. [Technical Report] N2361, ISO JCT1/SC22/WG14. 2019. ⟨hal-02089873⟩
Share
Metrics
Record views
52
Files downloads
170
