Nonparametric extreme conditional expectile estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scandinavian Journal of Statistics Année : 2022
Expectiles and quantiles can both be defined as the solution of minimization problems. Contrary to quantiles though, expectiles are determined by tail expectations rather than tail probabilities, and define a coherent risk measure. For these two reasons in particular, expectiles have recently started to be considered as serious candidates to become standard tools in actuarial and financial risk management. However, expectiles and their sample versions do not benefit from a simple explicit form, making their analysis significantly harder than that of quantiles and order statistics. This difficulty is compounded when one wishes to integrate auxiliary information about the phenomenon of interest through a finite-dimensional covariate, in which case the problem becomes the estimation of conditional expectiles. In this paper, we exploit the fact that the expectiles of a distribution F are in fact the quantiles of another distribution E explicitly linked to F, in order to construct nonparametric kernel estimators of extreme conditional expectiles. We analyze the asymptotic properties of our estimators in the context of conditional heavy-tailed distributions. Applications to simulated data and real insurance data are provided.
hal_revised.pdf (1.28 Mo) Télécharger le fichier
hal-02114255 , version 1 (29-04-2019)
hal-02114255 , version 2 (10-05-2019)
hal-02114255 , version 3 (30-06-2020)
Stéphane Girard, Gilles Stupfler, Antoine Usseglio-Carleve. Nonparametric extreme conditional expectile estimation. Scandinavian Journal of Statistics, 2022, 49 (1), pp.78-115. ⟨10.1111/sjos.12502⟩. ⟨hal-02114255v3⟩
536 Consultations
614 Téléchargements
