CertiCAN: A Tool for the Coq Certification of CAN Analysis Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper introduces CertiCAN, a tool produced using the Coq proof assistant for the formal certification of CAN analysis results. Result certification is a process that is lightweight and flexible compared to tool certification, which makes it a practical choice for industrial purposes. The analysis underlying CertiCAN, which is based on a combined use of two well-known CAN analysis techniques, is computationally efficient. Experiments demonstrate that Certi-CAN is faster than the corresponding certified combined analysis. More importantly, it is able to certify the results of RTaW-Pegase, an industrial CAN analysis tool, even for large systems. This result paves the way for a broader acceptance of formal tools for the certification of real-time systems analysis results.
main.pdf (385.61 Ko) Télécharger le fichier
hal-02119024 , version 1 (03-05-2019)
Pascal Fradet, Xiaojie Guo, Jean-François Monin, Sophie Quinton. CertiCAN: A Tool for the Coq Certification of CAN Analysis Results. RTAS 2019 - 25th IEEE Real-Time and Embedded Technology and Applications Symposium, Apr 2019, Montreal, Canada. pp.1-10, ⟨10.1109/RTAS.2019.00023⟩. ⟨hal-02119024⟩
158 Consultations
195 Téléchargements
