Supporting Volumetric Data Visualization and Analysis by Combining Augmented Reality Visuals with Multi-Touch Input - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2019
Lonni Besançon
Tobias Isenberg
We present our vision and steps toward implementing a collaborative 3D data analysis tool based on wearable Augmented Reality Head-Mounted Display (AR-HMD). We envision a hybrid environment which combines such AR-HMD devices with multi-touch devices to allow multiple collaborators to visualize and jointly discuss volumetric datasets. The multi-touch devices permit users to manipulate the datasets' states, either publicly or privately, while also proposing means for 2D input for, e. g., drawing annotations. The headsets allow each user to visualize the dataset in physically correct perspective stereoscopy, either in public or in their private space. The public space is viewed by all, with modifications shared in real-time. The private space allows each user to investigate the same dataset with their own preferences, for instance, with a different clipping range. The user can later decide to merge their private space with the public one or cancel the changes.
EuroVis2019Poster.pdf (3.84 Mo) Télécharger le fichier
Format : Figure, Image
hal-02123904 , version 1 (28-06-2019)
Mickael Sereno, Lonni Besançon, Tobias Isenberg. Supporting Volumetric Data Visualization and Analysis by Combining Augmented Reality Visuals with Multi-Touch Input. EuroVis Posters, Jun 2019, Porto, Portugal. pp.21--23, ⟨10.2312/eurp.20191136⟩. ⟨hal-02123904⟩
641 Consultations
555 Téléchargements
