Development and validation of a hybrid RANS/LES approach based on temporal filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To address the challenge of controlling the energy partition in hybrid RANS-LES methods, the use of a consistent operator based on temporal filtering is desirable. This formalism leads to the development of a consistent continuous hybrid RANS-LES approach called Hybrid Temporal LES (HTLES). In this paper, an upgraded version of HTLES is presented, focusing on improving the model for wall-bounded flows. Notably, a shielding function is integrated in the model to impose the RANS behavior in the near-wall regions. The calibration and validation of the hybrid method applied to the standard k-ω -SST model is then carried out on several test cases: decaying isotropic turbulence, channel flow and periodic-hill flow. The new version of the model fulfills the specifications: the correct subfilter dissipation; the correct migration from RANS to LES in the boundary layer; the robustness of the results to grid coarsening; the accuracy of the predictions at a reasonable computational cost.
Fichier non déposé
hal-02128250 , version 1 (14-05-2019)
  • HAL Id : hal-02128250 , version 1
Vladimir Duffal, Benoît de Laage de Meux, Remi Manceau. Development and validation of a hybrid RANS/LES approach based on temporal filtering. ASME - JSME - KSME Joint Fluids Engineering Conference 2019, Jul 2019, San Francisco, CA, United States. ⟨hal-02128250⟩
186 Consultations
0 Téléchargements
