Abstract : We present the validation of a scale to assess creature believability in videogames. We define Creatures as all zoomorphic entities not qualifying as fundamentally human-like, whether possessing or not anthropomorphic features. The scale, derived from a previous research, contains 26 items in 4 dimensions – Biological/Social Plausability, Relationship with the Environment, Adaptation, and Expression. The results of a Confirmatory Factor Analysis, using 19 subjects, originated a model with 4 factors, a CFI of 0.795, and RMSEA of 0.111. While not a good fit, it is very close to a mediocre fit, which is a potentially promising result. Further validation is needed with more subjects in the future.
https://hal.inria.fr/hal-02128616 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, May 14, 2019 - 1:52:22 PM Last modification on : Tuesday, May 14, 2019 - 2:34:08 PM
