Attributing and Referencing (Research) Software: Best Practices and Outlook from Inria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computing in Science and Engineering Année : 2019
Software is a fundamental pillar of modern scientific research, not only in computer science, but actually across all fields and disciplines. However, there is a lack of adequate means to cite and reference software, for many reasons. An obvious first reason is software authorship, which can range from a single developer to a whole team, and can even vary in time. The panorama is even more complex than that, because many roles can be involved in software development: software architect, coder, debugger, tester, team manager, and so on. Arguably, the researchers who have invented the key algorithms underlying the software can also claim a part of the authorship. And there are many other reasons that make this issue complex. We provide in this paper a contribution to the ongoing efforts to develop proper guidelines and recommendations for software citation, building upon the internal experience of Inria, the French research institute for digital sciences. As a central contribution, we make three key recommendations. (1) We propose a richer taxonomy for software contributions with a qualitative scale. (2) We claim that it is essential to put the human at the heart of the evaluation. And (3) we propose to distinguish citation from reference.
fullpaper.pdf (2.12 Mo) Télécharger le fichier
hal-02135891 , version 1 (27-05-2019)
hal-02135891 , version 2 (11-11-2019)
Pierre Alliez, Roberto Di Cosmo, Benjamin Guedj, Alain Girault, Mohand-Said Hacid, et al.. Attributing and Referencing (Research) Software: Best Practices and Outlook from Inria. Computing in Science and Engineering, 2019, pp.1-14. ⟨10.1109/MCSE.2019.2949413⟩. ⟨hal-02135891v2⟩
Relations
3529 Consultations
1114 Téléchargements
